Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch WAA24171GB/12
- This topic has 6 replies, 2 voices, and was last updated 15 years, 3 months ago by
Johnokent.
January 5, 2011 at 3:12 pm #59957
Johnokent
ParticipantWent to look at this today, machine has RINSE led flashing about 1 sec interval. Cannot clear this at all, Scanned through known fault codes can’t find faults code on this(is there one?) Apart from flashing LED machine is dead, door interlock not locking. any ideas. Interlock fault? Could’nt go to far today because of time and machine built into unit with drier on top. Dont you just love them!
Thought I’d run this past you clever lads out there
John
January 5, 2011 at 3:58 pm #340210Johnokent
ParticipantRe: Bosch WAA24171GB/12
Just had second thought on this, do these machines have flood switch? door gasket is not to good. As I said I couldnt get it out today so not able to look.
John
January 5, 2011 at 4:50 pm #340211Martin
If it is JUST the RINSE led that flashes?….then it’s a Motor fault.
HTH? 😀
January 6, 2011 at 8:33 am #340212Johnokent
Thanks, yes just the Rinse light flashing. No matter how program is selected, it would allow me to cancel out. door won’t lock nor does waste pump run.
Not sure how old machine is but does get a lot of use so are we just looking at worn brushes? or module. I’ll go back there today and extract machine from its hidey hole. Let you know how I get onregards,
John
January 6, 2011 at 8:46 am #340213Martin
Probably just the brushes, hopefully. The date code is the 4 digit FD number (FD????) by the way (e.g FD8806 = June 2008)…HTH? 😀
January 11, 2011 at 4:56 pm #340214Johnokent
Hi, just for info changed brushes, existing were well worn but not u/s. Flashing rinse light still showing. Checked motor and PCB over no obvious damage, but noted, no power to door interlock. Any other ideas? Looking more like board fault? from date code machine is only 2 years old but it in a busy pub restaurant so does get a LOT! of use.
John.
January 11, 2011 at 5:11 pm #340215Martin
Try resetting the machine. 💡
Hold the start button down for about 3secs and at the same time turn the dial one click to the 1 o’clock position. Release the start switch and put dial back to the off position. Hopefully that will reset it?
What was the megger reading on the motor by the way? ‘Cos sure as hell the fault lies there somewhere. 😉
