Re: Bosch WAA24171GB/12 fd 9002
rocker wrote:To be honest Martin, I also wanted some info, as if pcb is faulty will be unable to test, and of course cost !! cheers john
I recommend first adopting Andy’s line of attack (the interlock) before condemning the PCB. Or simply put your customer wise as to the ‘Worst case scenario’ of a duff PCB. The cost of which can be found on the Bosch website anyway. Unless you go look at it we can only stab in the dark starting with the interlock. Or it could be motor brushes? Heater? Etc….
