Bosch WAA28161GB/09 surging motor
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch WAA28161GB/09 surging motor
  • #83017
    allan73
    Could some kind soul please tell me what Tacho readings I should get on the motor for the above ?
    The machine is surging then cutting off.
    Allan
    #421467
    Re: Bosch WAA28161GB/09 surging motor
    if you spin the motor and set your meter on low ac volts you should see an output. if no output check for broken magnet
    is it a controlled surge ie does it speed you quickly or instantly
    if instantly suspect also the motor triac
    measure motor from board to rule out broken wires duff connectors etc
    allan73
    Thanks Dave, I’ve ruled our motor now must be the board.
    I’ve not had problems with motor triacs before on Bosch machines.
    Allan
