Bosch WAB28061GB/05 washer
  • #93177
    Gary59
    Hi All,
    Went to above appliance as advised won’t go into spin, clothes wet. Checked usual things and all functioning okay on visit.
    Customer rang a couple of days later and said filled but nothing else, so appeared no drum action. Wired on a new motor which took a while as this is one of those where you and the washer won’t fit in the same space!
    Anyway, it filled, tumbled for a few turns, then pumped out, spin light flashed and then door opened.
    Would be grateful for any pointers as difficult to test too much in cramped conditions.
    #453423
    Re: Bosch WAB28061GB/05 washer
    Gary59 wrote:Wired on a new motor which took a while
    I’m not altogether sure what you mean by that Gary but assuming the motor and brushes are OK then the symptoms suggest perhaps an earth leak on the heater?
    #453424
    Gary59
    Thanks Martin,
    Sorry yes, I actually fitted a new motor as had one, this was not easy in the space i had believe me. i checked the heater on my first visit and didn’t get any earth leak, but after I had left and thought about fault it did ring bells I think I have done another make that had dodgy heater and similar symptons, but as this job took me so long I was late for other jobs so didn’t double check everything. i will revisit with time and check. thanks
