bosch WAB28161GB/01
  • #97621
    suedehead1
    hi,
    it has an E21 fault I replaced the brushes and checked the motor but I cannot clear the fault code. I have tried the usual 6 oclock thing
    but to no avail.
    any ideas welcomed
    #468675
    is that the only one you have tried i thinlk there are 3 different reset routines
    try
    wab machines
    1) Close the door (The following operational sequence must take place after switching on the appliance)
    2) Set program selector to OFF position
    Wait for at least 2s
    3) Set program selector switch to position 15 while the Start/Pause button is pressed until display is active
    4) Release Start/Pause button
    All remanent errors will be reset
    suedehead1
    didnt try that one I will give it a go thanks
    #468678
    suedehead1
    that worked thanks very much
