Re: Bosch WAE 243664GB CLASSIX 6 1200
The symptoms not indicative of any specific fault I’m afraid. An error detected is normally displayed in the window ( e.g F:15). In the absence of such an error code then it’s time to unplug it and take a look inside. Motors and Heaters are a caution and so on though you will need a good grounding in electrical knowhow and the relevant earth insulation test equipment to go ahead.
Good luck! ( oh, and you might like to double-check the models number (ENr) you gave us 😉 )
