bosch wae 28467 uk strange bearing noise
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries bosch wae 28467 uk strange bearing noise
  • #61237
    funbobby
    second one i have come across in that when the belt is attatched there is a strange bearing knocking type noise like there is a bit of play in there. but when the belt is disconnected sounds fine not your usual bearing type rumble etc. is there a known issue with these?
    #345394
    loopey
    Re: bosch wae 28467 uk strange bearing noise
    it has to be the belt had a couple of bekos with the same fault , belt changed noise gone 🙂
    #345395
    funbobby
    really? completly sounds like its coming from the housing and the tension is making it knock in the housing?
    #345396
    funbobby
    tried belt but no difference, on second inspection sounds like its the motor thats the fault but not exactly cheap on these.
    #345397
    funbobby wrote:tried belt but no difference, on second inspection sounds like its the motor thats the fault but not exactly cheap on these.
    Wouldn’t harm to squirt a bit of 3 in 1 into the motor ballrace bearings to see if that helps? 💡
    #345398
    jason1970
    Had same fault with a Hotpoint recently. Does your drum pulley have flats on it? On the Hotpoint I had, drum pulley was slightly loose. When drum spun by hand, no noise, but with the tension from the belt the pulley would ‘knock’ as it slightly slipped!!! Bugger to tighten up though!
    #345399
    funbobby
    yea tightened the pulley and greased the bearings on the motor but no joy. think the motor is shot bit surprising on a bosch just over 2 years old.
    #345400
    keithwilliams
    i once had a queer ticking/knocking noise on a bosch. like you it only seemed to happen with belt on. after a bit of digging around i discovered that the tacho magnet was slightly loose on the armature. two spots of carefully placed superglue and the noise disappeared. mind you have to strip the armature out to do it. hold magnet with finger/thumb and see if you can turn it slightly back and forth. i cant really explain why, but it cured it.
