Bosch WAE lost its way,
  • #97002
    davethebrave
    Greetings from Australia. Door seal separated last week but machine still worked with water leaking out from door.Stupidly kept using while replacement was on way. Have replaced seal but now won’t cycle properly. Not getting an error code but gets stuck in a loop not completing cycle, draining or spinning properly. Behaves differently on different cycles.Tried the reset but machine was mid cycle at the time at hasn’t resolved. Any suggestions appreciated.
    #465781
    can you set a cycle or does it just start where it left off
    if you can set a cycle describe what it does and when
    davethebrave
    Thanks for the reply Dave. Can set cycle ok, starts as normal, fills up, then seems to get stuck doing the same thing- washing for approx 30 seconds then stopping for the same. When I interrupt it and try and set to drain or spin water dribbles out of the outlet and sounds like a pump is activating but doesn’t progress. Haven’t had opportunity to find any regular patterns in its behaviour.
    #465783
    are you sure the water is not syphoning out . lift the outlet hose up and hold it over a sink and see what happens
