Bosch WAE Touch Control Range
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch WAE Touch Control Range
  • #74641
    jess1ca
    Hi Can anyone on here had any trouble with reset… F21 which is Carbon brushes So whip motor out refit carbons to spec fit.. Refit motor back to position and start reset pattern as google info (hope this info is correct) but readout refuses to reset Question is.. Has the PCB now gone because carbon brushes have caused problem on the PCB Any answers please
    #392370
    Re: Bosch WAE Touch Control Range
    Disconnect the motor plug, do reset then plug motor back in. That often solves the problem.
    #392371
    jess1ca
    Thanx for that Much appreciated
