Hi gents need to clear error code on wae24060gb/02 rinse noen flashing change carbons tried 6 to 7 to clear code no worky it looks like a waa series machine to me do they use the clearing of code differently as it must be different as there is no spin speed button to hold like on a wae machine after a few goes now the start and wash neon is flashing and i am still locked out any help please alro
martin– it worked thanks– did find out off pos then anti clock to pos15 holding down start release anti clock pos 12 (9 oclock) press start for 3 secs release press start again it does test mode takes about 15 mins ends after 5 mins of spinning and stops door unlocks that clears error code and you can select any programme thanks again alro
