Bosch WAE24162 can the fault code be cleared?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch WAE24162 can the fault code be cleared?
  • #59592
    nelson
    Called to this one this morning customer complained of a blocked pump, I cleared the pump and when I tried to put the machine on test the 1200, 800 & rinse hold LED’s started to flash.
    I checked the machine over and found the carbons to be worn out, so I replaced them and tried again, still the same problem :rolls:
    When I have checked the known error codes thread just now, it would seem that the LED’s in question refer to a motor fault. Can the fault code be cleared or is it more likely that the motor is actually goosed.
    Cheers
    #338822
    loopey
    Re: Bosch WAE24162 can the fault code be cleared?
    i found this dont no iff it works tho
    hth
    To reset it.
    Turn the appliance knob to the off or reset position, 12 o’clock.
    Turn the knob to the 6 o’clock position.
    Press and hold the spin button.
    Whilst holding it, turn the knob to the 7 o’clock position.
    Continue holding the spin button for about 5 seconds.
    Release the button.
    Turn the knob to off.
    When your turn it back on it should have cleared the error code.
    #338823
    Beever
    suspect the motor or PCB is knackered, as you shouldnt have to clear a fault for the machine to work.
    Regards
    Ian
    #338824
    timdowning
    You do have to clear the fault on this range. Even if its a carbon brush change.
    #338825
    BobHope
    hi Nlson,
    i have emailed you some info.
    Bob.
    #338826
    loopey
    bob could you send me that info to please
    have pm you 🙂
    #338827
    nomadPaul
    This is the F:21 fault and will often lock the machine out . Its designed to stop the carbon brushes wearing down too much and thus preventing commutator damage.
    You have to enter the test programme to clear the fault code and get the machine working again….
    Appliances with displays will be F:21
    Appliances without display will be top middle and bottom spin speed LED’s
    #338828
    nelson
    😀 Thanks everyone for the replies, I shall try this out tomorrow.
    #338829
    suedehead1
    loopey wrote:i found this dont no iff it works tho
    hth
    To reset it.
    Release the button.
    i beleive this is correct i went to one with f21 in the display, i replaced the brushes and it still came up f21 did the above and the display rest and it worked ok.
    #338830
    nelson
    hth
    To reset it.
    Release the button.
    Just been back to this one and did the above procedure, and it worked a treat. 😀
    Thanks again everyone.
    #338831
    keithwilliams
    hi nelson
    you say that the above reset worked for you. i’m just wondering how you held down the spin button when in fact it is touchsensitive.
    do you continue to touch it, ie keep your finger on at all times, or did touching it once work.
    i’d like to know cos i sold quite a few of these and they’ll be due carbons soon.
    what part of northumberland are you in? i’m alnwick area.
    #338832
    Bernie
    I would also like to know as I have sold quite a few of these too.
    Also I just had this problem and I could not reset it.
    Bob could you send me that info to please.
    Bernie
    #338833
    nelson
    Hello Keith, yeah I just kept my finger on the button, and it worked a treat 😀
    I operate from Blyth BTW, but don’t get much further than Morpeth most of the time 😳
