Good Morning all
I have been out to the above washing machine with 1 and 3 and 5 spin lights flashing , motor fault replaced carbons still have the fault, have tried to clear error code doing the sequence of 6 o’clock hold spin button one more click to 7 o,clock hold for 5 seconds release and turn off but still have the fault, is this the correct reset?????
As far as I know on that range, that’s the correct reset.
be careful you are not going through the sequence too quick. I find if you allow about 2 secs between each step it seem to work better.
there are some engineers who say they cant do it with the motor plugged in but I have never had that problem
