Bosch wae24167gb 2 bleeps when start button pressed
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch wae24167gb 2 bleeps when start button pressed
  • #99051
    alro
    Hi gent have a bosch wae24167gb select programme press start and you get 2 bleeps and start neon flashing quickly programme will not start any help please cheers alro is there a child lock on this machine
    #474849
    kaibart
    Yes there is a child lock press and hold start button i think it is if not it wills how you in the instructions
    #474850
    had a few of the later type locks where the coil of the solenoid has snapped. seem to remember it was 3 beeps when it failed. Since the break is on the end of the coil i normally open the lock and solder the wire on again, sometimes extending it with fuse wire
    alro
    thanks dave coil wire broken in door lock but only 2 bleeps cheers alro
