Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bosch WAE2416sgb fitted new brushes now wont start, help!!!
- This topic has 11 replies, 4 voices, and was last updated 13 years, 9 months ago by
owy.
June 18, 2012 at 5:13 pm #70012
owy
ParticipantHi, I recently had an error code on my machine which said i had a motor fault. I changed the carbon brushes and the error code has gone. unfortunately it has been replaced by all lights on on one side and the top light(wash) on the other. The start light does not illuminate and the door does not lock. any suggestion please
June 19, 2012 at 12:11 pm #376743lasty
ParticipantRe: Bosch WAE2416sgb fitted new brushes now wont start, help
hi,if you turn wash knob to the off position then turn it to the 6 oclock spin position then press and hold the spin speed button then turn the knob to the 7 oclock position keep holding down the spin speed button for a further 5 seconds then turn the knob to the off position,this will reset the board, however it can take a few times to reset it when you have not done it before,hope this helps
June 19, 2012 at 3:32 pm #376744owy
lasty wrote:hi,if you turn wash knob to the off position then turn it to the 6 oclock spin position then press and hold the spin speed button then turn the knob to the 7 oclock position keep holding down the spin speed button for a further 5 seconds then turn the knob to the off position,this will reset the board, however it can take a few times to reset it when you have not done it before,hope this helps
THANKS i will try that now.
June 19, 2012 at 3:40 pm #376745owy
Hi Lasty just a quick question
does this work with touch sensitive buttons?June 21, 2012 at 3:49 pm #376746owy
hi ive tried that and it doesnt seem to work anyone have any other ideas?
June 21, 2012 at 4:20 pm #376747Martin
ParticipantBosch WAE2416sgb fitted new brushes now wont start, help!!!
Unplug the motor, then perform the reset procedure, then plug the motor back in..!
June 21, 2012 at 5:15 pm #376748owy
ok cheers i’ll give it a go.
June 22, 2012 at 1:14 pm #376749owy
hi martin thanks for the advice but im just vwiondering does this work with the touch sensitive buttons, as when i hold the spin button there is no button as such to hold in, sorry if im being really dumb here.
June 22, 2012 at 5:09 pm #376750Martin
owy wrote:sorry if im being really dumb here.
Before I answer, can I just ask if you have first disconnected the motor plug?
June 23, 2012 at 11:41 am #376751owy
i have disconnected the motor plug and tried the reset and then connected the motor plug back in but still no change. Iam at the point of giving up and buying a new machine(not an option i will take lightly) I have an engineer coming out this afternoon at a cost of £25, i dont really know what else to do
June 23, 2012 at 2:45 pm #376752steve1
hi
faulty pcb module?June 25, 2012 at 10:08 pm #376753owy
hello again, thanks everyone for your help.Ii have now fixed the problem. it was just a reset problem Lastys solution was the correct one unfortunately when i first turned the knob to 6oclock i should of waited for two flashes of the lights then moved it to 7 oclock, then release th spin button and turn to off, this instantly reset the machine. One again thanks for all the suggestions.
