Bosch WAE24363GB/02 F21 error
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch WAE24363GB/02 F21 error
  • #59261
    geoffmackay
    Have changed worn out brushes but machine still shows F21 fault. Have tried changing motors with no joy. Is there a way of clearing last known fault on module or is it likely the module has been damaged?
    Regards
    Geoff
    #337498
    nomadPaul
    Geoff , If you have a search , there are lots of posts on here about F21 error. You have to enter test mode to clear it.
    Selector dial to the off position
    Selector dial to the 6 o’clock position
    Hold down the speed select button
    turn selector switch 1 turn clockwise and release the spin speed button after 3 – 5 secs.
    This enters test mode.
    Now return selector switch to the off position and the fault should clear.
    #337499
    geoffmackay
    Re: Bosch WAE24363GB/02 F21 error
    Thanks very much Paul, will give it a go.
    Geoff
