Bosch WAE24363GB/05 1 min left
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch WAE24363GB/05 1 min left
  • #69829
    chitts
    I’ve been to this machine and could find no reason for the fault. The machine runs right through a cottons 40 cycle until 7 minutes left, when it goes to 1 minute, but completes cycle. All components test ok.I’ve replaced the pump because of excessive noise, but time problem still there. Any clues please?
    #376122
    Motor insulation too low?
    #376123
    chitts
    Re: Bosch WAE24363GB/05 1 min left
    Insulation on all components fine .Because machine had been on for a while everything was warmed up, so I think it would have shown up. Customer has used machine since and says it’s OK. Seems odd though. Maybe it was the pump after all.
    #376124
    nomadPaul
    The other possibility , if it happened only once , was an out of balance load where the machine aborted the spin ?
    #376125
    jason1970
    Have you visually checked the brushes? Sounds like worn brushes?
    #376126
    chitts
    Yes, first thing I did. Customers has confirmed after several washes, it’s not skipped a beat.
