bosch wae24363gb/05
  • #62351
    HotDog
    customer trapped clothing in door since then door will not lock tried new door switch still not locking display just showing -0- also when you select any prog the spin speed is stuck at 1200 is there a way of re-setting prog or could this be a board fault
    #349797
    scientist
    Re: bosch wae24363gb/05
    -0- is the symbol for the child lock. Not sure if this is on due to a fault or if by some reason it’s activated.
    #349798
    HotDog
    thanks for that customer has no instruction book so not not sure how to release i am sure if i go back it will obvouse
    #349799
    nomadPaul
    Press and hold the start button for 5 seconds to activate/de-activate child lock .
    You can also go online here http://www.bosch-home.co.uk/download-pr … nuals.html to download any instruction manuals
    #349800
    HotDog
    thanks sorted
