Bosch WAE24363GB/06 Changed Carbon Brushes – Now Very Noisy
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch WAE24363GB/06 Changed Carbon Brushes – Now Very Noisy
  • #69980
    minttea
    My WAE24363 stopped working after developing a noisy spin & showed the error code F21.
    We changed the carbon brushes, got it all back together & started a test wash. The machine is filling & going through the cycle fine & no more error codes but it is now very noisy with a loud, high-pitched whirring noise to accompany the drum turning / spinning.
    Can anybody shed any light on this please?
    As far as we know we put it back together all the same way it came apart!
    Many thanks in advance for your help.
    #376651
    You have fitted one or both carbons the wrong way around? You have fitted cheap nasty ‘pattern’ brushes? The commutator needs cleaning of carbon dust? The motor is knackered?……..that covers all I think you’ll find……
    #376652
    minttea
    Re: Bosch WAE24363GB/06 Changed Carbon Brushes – Now Very No
    Hi, thanks for the reply. The motor wasn’t making this noise before so I’m hoping it’s still sound. Machine is only 3 years old. We have fitted 3rd party brushes rather than Bosch – is that normally a problem? Pretty sure we got the brushes in the same way the old ones came out, we were careful to note the direction & match this up. There was a lot of carbon dust everywhere inside the machine, will take it apart again & clean commutator. When the motor is out of the machine, is it ok to vacuum out the dust with the narrow tube end of the vacuum? Thank you
    #376653
    Great idea!…out of interest…where did you buy the carbons from?
    #376654
    minttea
    eBay of course – quick & cheap 😉
    #376655
    No surprises then as to what you are experiencing.
    #376656
    minttea
    Ok, had to buy cheap for short-term, can replace will genuine part later on (few weeks) but in the meantime can we just put up with noise or is it likely to damage the machine? Thanks for all your advice.
    #376657
    minttea wrote:but in the meantime can we just put up with noise or is it likely to damage the machine?
    The odds are 50/50………
    #376658
    QUICK FIX
    have used to the so called cheap ones lenty of times and never had any problems
    #376659
    minttea
    Thanks QUICK FIX & Martin.
    Commutator now cleaned up & new brushes checked – definitely in the right way round.
    I found this other post on here post318765.html#p318765 which seemed to suggest new brushes can be noisy sometimes until they bed in so we cleaned everything, reassembled it & put it on a fast spin – noisy for a bit then settled down again & sounds almost normal now.
    Thank you UK Whitegoods people – this is such a helpful site for those of us who are financially challenged & have to learn a bit of DIY! 😀
