Bosch WAE24363GB/06 Strong Smell – Plastic/Chemical /Rubber?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch WAE24363GB/06 Strong Smell – Plastic/Chemical /Rubber?
  • #70780
    handle
    I had a Bosch engineer out to my washing machine today (hello if you’re on here) because my washing machine has been producing a strong smell which is kind of plastic / chemical / rubber – hard to describe but really strong & makes me light-headed.
    The engineer couldn’t find anything on the electrical tests etc but did find that the motor resistance was too low so a new motor was needed.
    As soon as the engineer had left, I ran the 60 degree ECO cottons wash & the smell was worse than ever, really strong, thought I was going to pass out from it :eeek:
    It’s not a dirty washing machine smell – I regularly run a maintainence wash.
    Can anybody please shed any light on what is causing this? I am not keen to just call out the engineer again straight away as my insurance (D&G) won’t pay for the visit if the engineer doesn’t find anything – if I have an idea of what it could be then at least I could know what to talk tot he engineer about.
    Thank you
    #378913
    jimca007
    Re: Bosch WAE24363GB/06 Strong Smell – Plastic/Chemical /Rub
    sounds like the smell you get from heat breaking down the varnish that covers the wires in a coil. There’s only really 2 places you get that. 1- the motor which by replacing assuming its a good replacement, has been eliminated and 2. the drain pump coil… something to check anyway.
