BOSCH WAE24363GB Washing Machine – Any way to extend pipes?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum BOSCH WAE24363GB Washing Machine – Any way to extend pipes?
  • #60822
    micky2008
    We may have to re arrange our current washing machine and tumble dryer setup as we cannot find a cheap condenser dryer that will fit in an awkward space we have (a radiator will block access to the water resivoir that will need emptying).
    I was wondering if its possible to extend the in and waste pipes (and probably use an extension lead for the power)?
    If so are these parts standard that i can pick up from a plumbers store or specialist that is only available from Bosch?
    #343789
    Specialist01269
    Re: BOSCH WAE24363GB Washing Machine – Any way to extend pip
    You should be able to find Inlet & Oultet hoses up to 3m long in stores such as B & Q or Focus Diy
    #343790
    Turbo
    Avoid running off electric extension leads, not good practice.
    Get an electrician to fit a proper 13amp wall socket within easy reach of the machine. Also make sure the socket is accessible without moving the machine.
    Graham
    #343791
    micky2008
    Id like to think there is enough pipe and lead.
    The washing machine and our current tumble drier sis side by side. the outlet/inlet and plug socket are all under meter away from current washing machine location. Hopefully switching the machines around will still leave me with enough pipe and cabling. 🙂
