Bosch WAE24363GB05 F21 Motor fault
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch WAE24363GB05 F21 Motor fault
  • #76667
    Taff
    Went to this job today F21 Fault. Carbons well worn out and were replaced. Meggered the motor before refit. Refitted the motor and could not reset the board. Switched off turn to 6 o’clock hold the spin button and switch to 7 o’clock, then switch off, no joy with or without the motor plugged in. Can anybody confirm I have the reset procedure correct, and if I have which module needs to be replaced the power or the control?
    #399394
    gandh1
    Re: Bosch WAE24363GB05 F21 Motor fault
    try it with the door open.
    did carbons on a 24364 today and tried quite a few times but it would not reset until i thought, hmmm try it with the door open 🙂
