Bosch WAE24367 leak under front dispenser
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch WAE24367 leak under front dispenser
  • #88678
    neilsukwg
    Anyone know the cure for this leak
    Started after 2 years use
    dripping out of the front of dispenser and running along the the ledge under the pcb?
    I have checked for level, raised front slightly and lowered water pressure.
    Still leaks
    Any ideas guys and gals?
    #438965
    nomadPaul
    Re: Bosch WAE24367 leak under front dispenser
    Have you checked for blockages in the fill hose ? I’ve also had problems where customers were putting tablets in the drawer designed to go in the drum and where they were a water softener block in with the detergent which was causing an overflow. .
