Bosch WAE24367GB/34
  • #78972
    allanh
    This washing machine has a strange problem. During wash cycle the unit works ok but does not seem to empty in rinse section. Eventually timer counts down to 1 and machine keeps tumbling but no spin/drain. Manually removing the water from the drum and running rinse and spin cycle with water supply turned off then works and machine rinses and drains off remaining water.
    No error codes reported but timing on main wash is not right
    Checked the pump by removing the filter and seems to spin up. Checked all hoses and they are clear unit is 30 months old.
    Problem seems to have started after it had an unbalanced spin and was switched off.
    Any thoughts
    #407493
    Re: Bosch WAE24367GB/34
    I’d take a close look at the pump and sump hose for starters.
    #407494
    timdowning
    If timings ok on rinse cycle & spin cycle then I would be checking the heater & wiring to heater.
    #407495
    allanh
    Thanks guys, I seem to have fixed this. Having stripped down all hoses and checked pump, checked all wiring plugs etc couldn’t find anything but after re-assemble it now appears to work ok. Done two washes today!
