put this machine on a 55 minute wash cycle.it has a timer display.
machine fills and rotates no problem. it also heats up while appearing to act normal. however the display counts down in real time to zero having only filled and washed. no rinse intake no drain out and refill. it basically retains the wash water. when it gets to zero the counter remains there however the machine continues to wash.
if you then cancel the cycle and reset it to rinse and spin it performs that perfectly.
any ideas ????
keith
