4 yr old machine. No previous problems. Wash cycles (2 different ones > mixed load and > super quick, have been attempted) are failing to complete. The display times-down to 01:00 mins but it then carries on washing and does not rinse or spin (seems to “stick” on 01:00). (The time displayed sometimes? appears to jump back to about 14/15 mins and then reduces to 01:00 again but the wash just continues). If switched off and then re-programmed to spin – this will complete. All the wash programs from 1 o’clock to 6 o’clock will start – but not all have been tested through to completion since the fault was first noticed. If the rinse/refresh cycle is selected as a new programme this will complete without any problem. If the spin only programme is selected this will also complete. Seems to me to be a potential programmer ? problem.
Does anyone recognise the fault?
Can anyone recommend a repair?
Re: Bosch WAE24467 1200rpm fails to complete wash cycle
Dave, many thanks – sounds like a good starting point and supports the direction I was starting to go in…
First time I’ve used this site – v impressed – thanks.
