I don’t know if anyone can help?
My Bosch washing machine has stopped working and gives me the error F17. Looking around the internet, I think that looks like the water inlet valve has had it. Is there an easy way to check this?
There’s plenty of pressure when I remove the feed pipe and open the cold feed isolator tap. When I run it on a 15 minute cycle (the quickest, therefore the easiest one to test the machine on) it opens the cold valve for about 5 seconds but that must only allow .5L of water into the machine. Definitely not enough for a wash. Does that sound like the valve is playing up or is there something else which could be causing the valve to close after such a short time?
cheers
Matt
