Hi all. I have a Bosch wae2816GB tripping the consumer unit 5 minutes or so into the wash. I have checked element pump and motor it fills heats emtys and spins but when on a programme it trips the consumer unit checked for earth leakage with meter and its ok .any help please. crockett
Sent from my GT-S5830 using Tapatalk
crockett wrote:checked for earth leakage with meter and its ok .
What of the supply, is the wall socket in order? Your megger reading has to be greater than 50 Mohms to be sure the machine is OK. The motor and heater are the most likely sources of trouble as you know.
By the way, you should post these questions in Trade Tech not General. 😉
Thanks Martin will check wall socket and have a closer look at everything in the workshop thanks again for your prompt reply.Apologies about wrong forum section I will use proper one front now on. cheers crockett .
