Bosch WAK24260GB/17 motor.
  • #89380
    aqualectric
    Bosch WAK24260GB/17 washer. FD9509.
    Machine wouldn’t spin properly so unplugged the small sensor plug from the motor and tried again. Span perfectly and seems to work as normal through several washes. I’ve looked up the part (00637879) – called a 3G sensor. Googled that and got a BSH video from BSH Chile and reading between the lines (my Spanish is not brilliant) it’s seems to be a motor mounted out of balance sensor.
    Question is why does the machine work fine with it unplugged? Does it harm the machine if left unplugged? I can replace it…. just curious about its function and necessity.
    Any ideas?
    Thanks,
    Steve.
    #441214
    Re: Bosch WAK24260GB/17 motor.
    would be interested to find its function, seems weird the machine it not setup to detect its not connected.
    not many people seem to have bosch info on here, one that springs to mind is NOMAD suggest you pm him and ask if he can help
    nomadPaul
    The 3g sensor is what’s detecting out of balance loads. I wouldn’t trust running it without it unless you want the machine walking across the floor !
    #441216
    aqualectric
    Thanks for the replies.
    I was interested to find out what it did as it didn’t throw a fault code. I guessed it might be an OOB sensor and even though I found the 3G sensor on BSH site I wasn’t sure exactly what it did.
    Thanks again!
    Steve.
    #441217
    aqualectric
    One more question….. do these sensors fail often and is there anything obvious that causes it?
    Steve.
    #441218
    nomadPaul
    They don’t fail that often . There are occasions when the motor gets noisy (even from new) and that can cause problems with the 3D sensor (probably electrical noise interference) The ones that do fail tend to show up fairly early in their life .
