Bosch wak28260gb11
  • #88721
    ddirect
    Bosch wak28260gb washing machine will not go into full spin. The symptoms are as if it is out of balance so therefore refusing to spin even with no load in it. It fills and drains ok. Any thoughts much appreciated.
    Darren
    #439161
    Re: Bosch wak28260gb11
    Looking at the schematic it has a ‘3D sensor’ connected to the side of the motor which may has some bearing? What it does I have no clue, sorry. 😕
    #439162
    ddirect
    Yes I spotted it and no I have no idea what it does either, thanks for looking.
    #439163
    nomadPaul
    Is this still under warranty? The 3D sensor is used for the out of balance system and there has been a problem with them causing the symptons you’ve described. Basically the appliance won’t spin as it thinks it’s always out of balance.
    #439164
    ddirect
    It’s not under warranty, I will be ordering the part today, thanks for taking time to reply.
    Darren
    #439165
    ddirect
    just to confirm a knew 3D sensor fixed it thanks for the help.
