Bosch wan 28201- lock won’t go down, can’t close door
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch wan 28201- lock won’t go down, can’t close door
  • #97383
    Pj Lloyd
    Hello,
    I recently bought this washing machine. I had to take the door off to fit it into the utility room but when I put it back on the lock (latch?) was up and I couldn’t shut the door.
    I called the supplier but they refused to take it back as I had taken the door off and I can’t get hold of the local engineer they gave us a number to get it fixed.
    I tried the release at the bottom of the machine but this isn’t working either.
    I have two children under 2 so the washing is really piling up and I becoming a little desperate. Thanks in advance!
    #467416
    what do you mean the latch was up ?
    Pj Lloyd
    Hi Dave,
    My wording might be off. I think it’s the latch that keeps the door locked when a wash is on. This is up/engaged with the door open meaning I can’t close it
    #467418
    andyjawa
    Well the bit on the door is called the hook but that should not move. The electric lock ( the part behind the front chassis front ) could be suspect. Are you sure that the door hinge is in seated in the chassis front cut out holes that the door hinge seats down into before the screws are fitted through the door hinge?
    #467419
    Pj Lloyd wrote:Hi Dave,
    if that is the case you will need to hook something in it and pull it forward
    find an old wire coat hanger and cut off about 8 inches or so
    fold over one end to make it safe
    fold about half an inch the other end at 90 degrees
    make sure the machine thinks the door is open, hook this in the lock and pull it towards you into the unlocked postion
    Mihangel
    This model is capable of seeing the position of the lock and if the hook is engaged. If it’s not unlocking the lock as soon as you turn the machine on then the lock is faulty
    #467421
    Mihangel wrote:This model is capable of seeing the position of the lock and if the hook is engaged. If it’s not unlocking the lock as soon as you turn the machine on then the lock is faulty
    as you close and open the door the lock is in the unlocked state to allow the door to open and close. could the mechanism be in the closed but unlocked state which would prevent the door from closing. similar to the problems dishwasher door locks have ?
    Mihangel
    It could be in the closed position as you say, but if the lock is working the machine should see this and unlock it or throw up an error (can’t remember what it is off the top of my head). Otherwise it’s most likely a faulty lock. I’m also unsure as to how taking the door off would cause this, I suspect there’s more to this story that we’re not getting
