Bosch WAN28081GB/38 washing machine door lock chatters
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch WAN28081GB/38 washing machine door lock chatters
Viewing 1 post (of 1 total)
  • #103423
    Twoten
    Fault originally reported was the door symbol stays on and the machine doesn’t start.
    It appears someone may have taken the door seal off the front of the machine, so tampering is a possibility.
    I found the interlock connector separated and one of the wires out. I first assumed the wire had broken so I opened the block completely to check there was no debris left inside to prevent the cable being refitted. I noticed none of the wires inside the connector had cut marks from the crimps inside the connector.
    I refitted the wire that had come out and closed the connector.
    When testing, the interlock now chatters for about 1 second then stops.
    I can’t be sure of the integrity of the interlock wiring loom, so have suggested we replace this with the interlock.
    Does anyone have a wiring diagram for this model?
    Thanks.
