Bosch WAN28100GB/19
  • #99330
    andyjawa
    Hi. I`ve come unstuck. Coming up with E35 fairly often which elsewhere on the i/net points to a basal leak detected which is odd because there is no base fitted via the Bosch parts drawing and no flood sensor float listed which just confirms that. Elsewhere it points to poor fill sensor ( that troublesome flow sensor on the valve ) except it is your normal bog standard Bosch double valve.
    Question is can anyone give me a boot in right direction please.
    #475884
    bosch codes are hard to find but one link I found points to a possible pressure sw problem
    andyjawa
    That is certainly a good pointer. Many thx for going to the trouble.
    Developments: I`ve just learnt that apparently this machine has been a demo model in a building site sales development agent`s office, so it all transpires, before it was flogged off cheap to a buyer and because I have not been to see this thing yet I wonder if it is in some sort of special programme mode as a possibility. And if it is then I will have to ask the question how the hell do you get out of it to reset it? If anyone knows the answer please let me know just incase so I can go armed with the necessary info. Thx once again.
    #475886
    andyjawa
    Ignore my last post paragraph “Developments” it was never a demo machine afterall. Conflicting info as is usual!
