Bosch wap28360gb/14. Fd 9208 200050
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch wap28360gb/14. Fd 9208 200050
  • #79528
    Andy jones
    Hi guys
    Customer showed me a video of the machine making some strange scraping/ juddering noises coming from the machine. At first I thought something had got jammed between the drums. I have eliminated that and think its motor related.
    This has a small 3 phase motor ( looks like it belongs in a vacuum cleaner 🙂 )
    Just wondering if anyone else has had any dealings with these
    Andy
    #409563
    Re: Bosch wap28360gb/14. Fd 9208 200050
    It’s not the sensor scraping on the drum pulley is it?
    #409564
    Andy jones
    Thanks for that martin. Don’t think so as it only does it very occasionally
    #409565
    nomadPaul
    It’ll be the motor module…..and the appliance should still under the Bosch 2 yr warranty.
    #409566
    Andy jones
    Thanks nomad. I have asked them to contact Bosch anyway
    #409567
    nomadPaul
    The failure of the motor module gives a symptom as if the drum is jamming . It will squeak and jerk as if something is stopping the drum from turning freely. There will probably be an error code of E:74 or E:75 in the test programme memory.
    Weirdly , if you run a motor test cycle it normally doesn’t actually mis-behave.
    #409568
    Andy jones
    Exactly what’s happening but no fault codes
    #409569
    jason1970
    Hi nomadPaul
    How would you get to the test programme on this model?
    Jason
    #409570
    nomadPaul
    Off the top of my head , it should be the selector switch round to the 6 o’clock position , hold the spin speed button and turn selector switch one click clockwise.
