Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bosch WAQ283S0GB/12
- This topic has 12 replies, 3 voices, and was last updated 3 years ago by
Jenny Vel.
March 21, 2023 at 3:11 pm #101819
Jenny Vel
ParticipantHi,
I have E43 error code showing on my machine. Looking on line it looks likely to be the brushes. How do I tell if its the brushes or the bearings or something else (preferably without dismantling as I don’t have a clue what I’m doing!)?
I gather the bearings aren’t actually economically changeable. Is that correct?
If its a reasonable fix Id like to try.
Thank you!!
March 21, 2023 at 5:52 pm #486282electrofix
Moderatorwont be bearings unless the drum has jammed
does the machine come up with the error code as soon as turned on ?
March 21, 2023 at 8:18 pm #486283Jenny Vel
ParticipantHi Dave,
Thank you for the response.
The drum is not jammed ( i.e. I can manually move it freely) and yes as soon as I switch the machine to any setting the error message comes up.Jenny
March 21, 2023 at 8:26 pm #486284Jenny Vel
ParticipantSorry just re read my response.. So yes the error message comes up straight away. J
March 21, 2023 at 8:56 pm #486285kaibart
ModeratorE43 is a motor 3d 3g sensor blocked drum caused by laundry, motor is blocked this is what the error means
March 21, 2023 at 11:14 pm #486286electrofix
Moderatorhow old is the machine
if you dont know post the FD number
March 22, 2023 at 10:50 am #486287Jenny Vel
ParticipantThank you. The FD is 2910001488.
March 22, 2023 at 12:51 pm #486288electrofix
Moderatorthat makes no sense, are you sure of that number
from that it was made either 1949 or 2049 both of which cant be true
was trying to figure how old it was to get an idea of work its done. if its 5 to 7 years or so with above average wear then it could indeed be brushes
but someone would have to strip the machine to conform or dent thisif you dont have a clue then you need professional help
suggest you look here to see if one of our members is close to you
Find an appliance engineer to repair any appliance using our free service (ukwhitegoods.co.uk)
DaveMarch 22, 2023 at 1:50 pm #486289Jenny Vel
ParticipantSorry Dave, I mixed up a number its 9210001488. Dads got an engineering back ground so Im hoping if I establish what it is and get the parts he can sort it.
Thank you.March 22, 2023 at 8:39 pm #486290electrofix
Moderatorthats 2012 october
thats more like itat that age its likely the brushes have failed. you would have to remove them to check. be careful you note which way up they are as the end of the brush is angled to contact the armature
https://www.bosch-home.co.uk/store/00605694#/Togglebox=manuals/
after the brush is fitted the machine will possibly need to be reset.
will help with that when you know where your going
cant promise this fault is correct but its highly likely
March 31, 2023 at 9:17 am #486291Jenny Vel
ParticipantThank you so much. I have had some brushes delivered so we will see how we go 🙂 fingers crossed J
March 31, 2023 at 10:33 am #486292Jenny Vel
ParticipantOk they are in 🙂 Machine is all back together. How do we do the reset? Thank you!!
March 31, 2023 at 10:49 am #486293Jenny Vel
ParticipantDont worry we have managed to do it. Thank you all so much!! Have a good weekend. J
