What’s the reset procedure to clear error codes, appliance keeps popping up error codes, when visiting unit goes through cycles
with error code still in display window
some error codes reset every time a new programme is started
if this is you then you need to find out what the error means
there are 3 bosch resets from memory starting with the original turn to 6 oclock and hold spin button one. search forums they are there somewhere but it will only work on fault codes that don’t reset every time
