bosch waq28461bg/12
  • #86391
    delta01
    hi this machine starts filling then stops all lights go out for a few seconds then back on eventually it displays e29 , i checked inlet valves they seem ok pupm and motor action ok any help appreciated thanks john
    #430995
    Re: bosch waq28461bg/12
    this has got to be a main board fault. with all the lights going out sounds like the board either crashes or runs out of power
    have you tries just a rinse cycle? sometimes with power problem machines will run a rinse cycle because it does not need to activate heater or soap box but fail on anything else
    delta01
    thanks Dave its what i suspected will inspect board for faulty components / damage
    John
