Bosch WAS24466GB/05 WM Reset Procedure
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch WAS24466GB/05 WM Reset Procedure
  • #72960
    Poppins
    Can anyone tell me the reset procedure to use on this machine please? It has the touch sensitive buttons and the procedure I have used on other Bosch’s doesn’t work. I can’t find anything in the forums.
    For info, the brushes had worn.
    Cheers Chris
    #386087
    timdowning
    Re: Bosch WAS24466GB/05 WM Reset Procedure
    The reset is the same as the WAE range. The one where you turn it to 6 oclock and hold the spin button etc, etc.
    I suppose if you’ve tried the reset with or without the motor plugged in, then the board may have gone? Its worth giving it a few more tries as I do find these touch sensitive buttons not very responsive to my knackered finger tips.
    #386088
    Poppins
    Hi Tim,
    Thanks for your reply.
    That was the standard procedure I tried.
    I have also tried turning the dial to one o clock and that didn’t work but I have just discovered in the related topics someone had used the 11 o clock position so i will be returning this afternoon to give that a go.
    We could do with a list of reset procedures stuck at the top of the technical forum particularly for these Bosch/Siemens machines. Is that easy to do Mods?
    Cheers Chris
    #386089
    Poppins
    Tim,
    When I go back I’ll try all of the procedures I have discovered so far.
    Thanks anyway
