Bosch WAS28460GB nr0 error
  • #62895
    odom
    Hope someone might have come across this before. Six month old machine that had been dropped by some clumsy builders. Machine now keep flashing “nr0” on the digital display.
    Originally still trying to complete programme and keeping door locked, managed to get programme to finish by doing reset board 6 o’clock thing. Now machine won’t start any programme, as soon as you press Start is just beeps and displays nr0.
    Checked for insulation (over 3k Mohms) and loose connections on both PCBs but all seems fine, except the bottom two options (Aqua Plus and Easy Iron) don’t respond. Really annoying as I’m sure it must be something simple but I’m a bit stumped as can’t find any reference to nr0 anywhere.
    Thanks in advance for your help!
    #351646
    HotDog
    Re: Bosch WAS28460GB nr0 error
    I now it sounds to easy but i got stuck on a bosch coming up with -0- in the display i was informed it was on child lock could it be ??
    #351647
    nr0 does indeed mean the Child Lock has been activated. Simply press and hold the ‘Start’ button for over 5 secs to deactivate it. 😀
