Bosch WAS28461GB/07 E29 fault.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch WAS28461GB/07 E29 fault.
  • #79293
    aqualectric
    Bosch WAS28461GB/07 FD9111.
    Turn to any cycle that fills, press start and about 10 seconds later “E29” flashes up in the display and beeps but only for about 30 seconds. The code disappears and the machine continues on as usual. Completes the cycle perfectly. 😕
    Any ideas on E29?
    Thanks,
    Steve.
    #408720
    Micky 32
    Re: Bosch WAS28461GB/07 E29 fault.
    Sounds like low water pressure going into the machine, check filters on the inlet pipes not blocked.
    #408721
    nomadPaul
    E.29 is def no water detected by flow sensor so Micky 32’s advice is sound
    #408722
    Micky 32
    How i know is when at home my mother has a similiar machine and if it’s on and i turn on a tap that code beeps up :rotfl:
    #408723
    aqualectric
    Thanks guys; really appreciate the help!!
    Cheers,
    Steve.
    #408724
    Steven
    I have a Bosch and a Siemens washer that occasionally comes up with this error initial fill starts beeping e29 while still filling water pressure ok and filter clear. Then after it continues through cycle ok?
    When you say sensor on the replies do you mean the pressure switch?
    Strange why it only does it sometimes some washes work perfect.
    Cheers
    Steven
    #408725
    as with a lot of appliances these days there is a sensor on the inlet valve that senses water flow
    Steven
    Why o why, thanks and cheers for the info.
