Bosch was28466 F43
  • #66205
    bazza500
    Went to this with F43 showing and found brushes worn. I have replaced the brushes but after the machine is switched on for about 3secs then the F43 comes back on the display. This is before pressing the start button and it doesn’t matter what program is selected.
    Does this machine need reset after a fault is fixed? I have checked the motor and it is fine.
    Barrie
    #363456
    timdowning
    Re: Bosch was28466 F43
    Yep reset as the WAE range.(Did one a few weeks ago.)
    #363457
    bazza500
    Where do I find the reset sequence?
    #363458
    timdowning
    Here you go:
    Set selector switch to off then turn the selector switch to the 6 o’clock (spin) position. Then press and hold the spin speed selector button whilst turning the selector switch one more click to the 7 o’clock (drain) position. Release spin button then turn selector to off.
    I just searched F43 to get this in case you need more info.
