Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › bosch was28466gb/01
- This topic has 15 replies, 8 voices, and was last updated 15 years, 11 months ago by
adv.
May 6, 2010 at 2:05 pm #54426
adv
Participantwont drain quickly. had a look at this sump clear. draining slowly am thinkin week pump or blockage in drain hose. got that stupid hose that joins at top of machine.cant see anthing stuck in pump housing, any how , how do you get the front of these. done usual screw in soap draw an two bottom srews but wont come off. help ta 😳
May 6, 2010 at 4:04 pm #319546nomadPaul
ParticipantThere are two hidden screws behind the control panel .
May 6, 2010 at 4:07 pm #319547adv
ParticipantRe: bosch was28466gb/01
thats stupid aint it, how does control panel come off? an is ther a cheaper pump you can fit rather than 144511 £65 job?
May 6, 2010 at 5:19 pm #319548superfix
Usual to remove fascia. Has to be that pump due to new style hose connection on pump.
May 6, 2010 at 5:35 pm #319549adv
i havent had to remove facier before. do you have to prize it of. ie is cliped on or is it screwed on,?thanks and wat bowt timer knob. does just pull of or what? 1st time one of this model, older model was so easy mmm 😳
May 6, 2010 at 6:37 pm #319550superfix
screws behind soap drawer. clip on rhs on the inside. timer knob comes away with fascia and control pcb.
May 6, 2010 at 10:22 pm #319551leavemetogetonwithit
adv wrote: an is ther a cheaper pump you can fit rather than 144511 £65 job?
£45.52 retail at Bosch. Still expensive. Can’t find a pic anywhere except for cartoon on Bsh site but would have thought something else would fit to the filter.
Mike.May 6, 2010 at 10:26 pm #319552adv
thanks lads 😆
May 6, 2010 at 10:49 pm #319553adv
mmm wi vat an postage £64 not good 😳
May 6, 2010 at 11:10 pm #319554Galway
i had one of about a year ago and i did a lot of head scratchinng but eventually found two coins stuck in the part where the hoses join at the top of machine .i dont know how they got up that far.
May 6, 2010 at 11:13 pm #319555leavemetogetonwithit
How far away is the job? I’d suggest taking along a small selection of standard pumps, both screw and bayonet fit and some silicone sealant, some epoxy putty, some cable ties, some green gardening wire, some self tappers, some speednuts…you get the picture. One word of caution. If the old pump has a toc, make sure the replacement does too.
Anyway, it’s just as likely a coin acting as a flap valve.
Mike.May 7, 2010 at 12:23 am #319556Penguin45
Pump is £38 from Masterprt – a bit better.
May 7, 2010 at 8:23 am #319557Martin
leavemetogetonwithit wrote:How far away is the job? I’d suggest taking along a small selection of standard pumps, both screw and bayonet fit and some silicone sealant, some epoxy putty, some cable ties, some green gardening wire, some self tappers, some speednuts…you get the picture.
Mike, you missed out double-sided sticky tape, cling film, bottle brush, stirrup pump and various sizes of Jubilee clips….absolutely vital on jobs like this I reckon. 🙂
May 7, 2010 at 8:50 am #319558robbo1973
what about a cuddly toy!!!
May 7, 2010 at 9:24 am #319559adv
lol 😆
