bosch was28466gb/01
  • #54426
    adv
    wont drain quickly. had a look at this sump clear. draining slowly am thinkin week pump or blockage in drain hose. got that stupid hose that joins at top of machine.cant see anthing stuck in pump housing, any how , how do you get the front of these. done usual screw in soap draw an two bottom srews but wont come off. help ta 😳
    #319546
    nomadPaul
    There are two hidden screws behind the control panel .
    #319547
    adv
    Re: bosch was28466gb/01
    thats stupid aint it, how does control panel come off? an is ther a cheaper pump you can fit rather than 144511 £65 job?
    #319548
    superfix
    Usual to remove fascia. Has to be that pump due to new style hose connection on pump.
    #319549
    adv
    i havent had to remove facier before. do you have to prize it of. ie is cliped on or is it screwed on,?thanks and wat bowt timer knob. does just pull of or what? 1st time one of this model, older model was so easy mmm 😳
    #319550
    superfix
    screws behind soap drawer. clip on rhs on the inside. timer knob comes away with fascia and control pcb.
    #319551
    adv wrote: an is ther a cheaper pump you can fit rather than 144511 £65 job?
    £45.52 retail at Bosch. Still expensive. Can’t find a pic anywhere except for cartoon on Bsh site but would have thought something else would fit to the filter.
    Mike.
    #319552
    adv
    thanks lads 😆
    #319553
    adv
    mmm wi vat an postage £64 not good 😳
    #319554
    Galway
    i had one of about a year ago and i did a lot of head scratchinng but eventually found two coins stuck in the part where the hoses join at the top of machine .i dont know how they got up that far.
    #319555
    How far away is the job? I’d suggest taking along a small selection of standard pumps, both screw and bayonet fit and some silicone sealant, some epoxy putty, some cable ties, some green gardening wire, some self tappers, some speednuts…you get the picture. One word of caution. If the old pump has a toc, make sure the replacement does too.
    Anyway, it’s just as likely a coin acting as a flap valve.
    Mike.
    #319556
    Pump is £38 from Masterprt – a bit better.
    leavemetogetonwithit wrote:How far away is the job? I’d suggest taking along a small selection of standard pumps, both screw and bayonet fit and some silicone sealant, some epoxy putty, some cable ties, some green gardening wire, some self tappers, some speednuts…you get the picture.
    Mike, you missed out double-sided sticky tape, cling film, bottle brush, stirrup pump and various sizes of Jubilee clips….absolutely vital on jobs like this I reckon. 🙂
    #319558
    robbo1973
    what about a cuddly toy!!!
    #319559
    adv
    lol 😆
