Bosch WAS28466GB/05 washing machine will not start
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch WAS28466GB/05 washing machine will not start
  • #81786
    MARIO
    Hi can anybody help got a Bosch WAS28466GB/05 washing machine will not start.When you press start it beeps twice door does not lock .Cust says machine had blocked pump which he cleared and then would not start. I carried out reset but still the same . No fault code being displayed . Could this be door switch fault or panel fault . Trouble is door switch £ 40.00 plus exspensive guess any help appreciated
    #417712
    Re: Bosch WAS28466GB/05 washing machine will not start
    Try operating the door lock manually. It could be the male probe on the door isn’t engaging properly (cracked door surround)…??
    #417713
    MARIO
    yes thanks Martin have tried that and it still did not start .Have you any other ideas
    #417714
    What about the interlock connector, is it plugged in securely? Or maybe the PCB is blown, time to inspect?
