Re: Bosch WAS287B0GB (A/W)
I will try to explain, hope this works for you 😉
Select the Spin (6 o’clock position)
Press the <Options button
Whilst holding the <Options button turn dial one more position clockwise then release the button. Rotate dial back to the Spin position. That should display (hopefully at least?) the current language it is set at. Then use the + or – button to scroll through the various languages. Once the language you require is displayed then rotate the dial to the Off position.
The language should now have change once the program knob is rotated to any program.
Waiting with baited breath at the outcome 😉
