Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › bosch was32461 clothes still wet
- This topic has 7 replies, 4 voices, and was last updated 10 years, 7 months ago by
char14lew.
August 13, 2015 at 5:16 pm #85809
char14lew
ParticipantI have a problem with the above machine.It seems ultra sensitve to an unbalanced load.The thing is not overloaded and the clothes are loaded small garment,large garment to evenly distribute the weight.The correct programme is selected for 1200 spin and it won’t get there at the end of the normal cycle.The clothes come out soaking still.But if spin individually selected afterwards,it will spin the clothes!
any pointer’s please?
thanks in advance!August 13, 2015 at 7:43 pm #429564Martin
ParticipantRe: bosch was32461 clothes still wet
Restricted drain issue? Have you checked the drain filter lately?
August 13, 2015 at 8:36 pm #429565char14lew
thanks Martin,but if there was a blockage would it still spin and drain as normal when the spin cycle is individually selected?i will check it though.
i was wondering if there was a sensor that could be replaced.I’ve read the LG’s have a problem with unbalanced loads.
I personally have an eight year old was24466 and that will spin anything,it’s been a great machine!
thanksAugust 13, 2015 at 9:19 pm #429566Martin
Small loads of ‘heavy when wet’ will never distribute correctly. (One bath towel for example). So it will never complete a cycle and spin correctly. 4 or 5 bath towels, no problem.
If unbalanced is NOT an issue then the time it takes to drain the rinse water will be to blame. Bosch are natorious for drain pipes getting gunged up. Like blocked human arteries trouble isn’t far away.
Try testing how quickly the tub drains on a rinse and spin only cycle WITHOUT any washing in. A full rinse tub should empty within 45 seconds or less.
August 14, 2015 at 6:57 am #429567wilf
I had a similar problem turned out the heater was o/c. dont know why this would cause intermitant spin faults but no further faults reported.
wilf
August 19, 2015 at 7:39 pm #429568char14lew
thanks guys
August 19, 2015 at 7:48 pm #429569wizard
Had one doing this a couple of months back – was the 3d sensor(lines up with big magnet on top rear of drum) . Wiz
August 19, 2015 at 8:13 pm #429570char14lew
cheers
