Bosch WAS32466gb/05 Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch WAS32466gb/05 This topic has 4 replies, 2 voices, and was last updated 13 years, 10 months ago by robbra. Viewing 5 posts - 1 through 5 (of 5 total) Author Posts May 29, 2012 at 1:40 pm #69700 robbraParticipant Brushes worn down, changed them and motor checks out ok. the machine will display the prog selected but nothing, door doesn’t lock. Is there a reset for this or have I missed something? Thanks Rob May 29, 2012 at 3:48 pm #375725 MartinParticipant Bosch WAS32466gb/05 Unplug motor then try reset then plug motor back in. Failing that the motor has stuffed the PCB most likely. May 29, 2012 at 5:00 pm #375726 robbraParticipant Re: Bosch WAS32466gb/05 Thanks Martin. Is the unplug the reset procedure or is there a sequence to go through? May 29, 2012 at 5:54 pm #375727 MartinParticipant Bosch WAS32466gb/05 The normal reset procedure with the motor unplugged, then plug the motor back in should (hopefully) clear the error. May 30, 2012 at 6:24 am #375728 robbraParticipant Re: Bosch WAS32466gb/05 Thanks again Author Posts Viewing 5 posts - 1 through 5 (of 5 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
