Bosch WAS32466GB/05
  • #90672
    Hello Chaps,
    Having a problem coding the pcb on the above machine. Have followed the instructions to the letter (I think…), but the board has not accepted the codes correctly. Therefore, I need to re-enter the coding mode – set knob to position 12, hold down spin and move to 11. This doesn’t respond at all, simply bringing up programme information.
    Any advice, hints or tipped gratefully received!
    Cheers,
    Chris,
    P45.
    #445579
    BSH-MAN
    Re: Bosch WAS32466GB/05
    If incorrect coding has been set, then the button you hold down when turning the knob may have changed. Had this following a B.G. Repair, had to try each button in turn until I found the right one.
    #445580
    nomadPaul
    The button used to select the test/coding mode is the spin speed button so if the buttons are out of order them you’ll need to find the spin speed ‘changer’ to get into the program.
    #445581
    Thanks gents. The time delay button is currently the spin speed button. I’ll get it figured out.
    P45.
    #445582
    nomadPaul
    The coding that needs changing is the ME section. There souks be a number on the for label that starts with ME i think and it’s important that this is correctly entered on the coding. The correct setting should be on the coding sheet.
