BOSCH WASHED MACHINE e 23
Home Forums Public Support Forums Help And Support Washing Machine Help Forum BOSCH WASHED MACHINE e 23
  • #85456
    anghelionel
    hello,i have a washed machine bosch maxx plus with a E 23 error code.can u help me please?
    #428653
    Muv
    Re: BOSCH WASHED MACHINE e 23
    The E23 code means that a leak to the base of machine has been detected..
    You need to check underneath the machine after removing the bottom cover..
    There is a float device attached to this base so be careful when removing as the wires are notmthat long…
    Youncan then pull off the commector and investigte where the leak is coming from….
    But it could be just a case of water leaking in tomthe base if you have recently cleaned out the fluff filter.. Try putting some towels infront of the machine and tilting forward to let any remaining water run out of the front and on to the towels…
    If it then happens againyou have a leak that needs sorting..
    Hope this helps
