Bosch washer
  • #92895
    kaibart
    Bosch wae24063 gb/30 trips electric insulation check over 400meg ohms trips after 5 mins on. Any ideas I’m sure it’s motor fault
    #452499
    alster
    Re: Bosch washer
    Probably heater. If you megger machine empty the heater is isolated. Take the front off and megger the heater. Hope this helps. Al.
    #452500
    kaibart
    Re: Bosch washer
    When it tripped the electric after 5 mins it would trip straight away when I switched it back on didnt think the heater would cause that had a motor do it on 1 before that showed fine when i meggared it
    #452501
    alster
    Re: Bosch washer
    Heater relay cuts in after about 5 mins. If you switch it back on after tripping prog carries on from same place so relay cuts in straight away. I might be wrong but still sounds like heater to me!! Al
    #452502
    Re: Bosch washer
    since the unit will run without the heater. pull the 2 wires off the heater and try it
    dave
    #452503
    Simon46
    Re: Bosch washer
    Had a heater cut through by drum. Meggered fine at mains plug but failed when directly connected to element.
    #452504
    kaibart
    Re: Bosch washer
    Ok cheers lads will take another look at it
