model enr wae24366/gb/23
fd 9007
client says error code f18 came up
he did some research says its water not draining
called to investigate
filled with water..switched to drain only
nothing..other than door intelock clicking and door will open
took pump of it runs fine on bench test
no voltage at pump connections
refitted same when set at drian 01 comes up in display,,then no and yes flash
it sems to have some how got into engineer mode
dont know why as i have only programmes one wash cycle and drain
anyone have an idea
thanks
Graham
